rvman69
Jun 13, 2023Explorer
John, Thanks for the photos and information. Well I have had it plugged in for 6 hours. All of the lower pipes I can reach 6 thru 12 on your diagram are still cold to the touch. So there is no movement in the cooling unit is this correct? The flue is so hot all I can do is tap it with my finger with out get burned or blistered. I am pretty sure it is not working at all. I got a feeling I am going to be ordering a cooling unit. I know it takes a long time for it to start cooling down inside fridge and freezer but it should start circulating in 6 hours correct? Just as a note after 6 hours the temp in the freezer and fridge did not drop at all. Thanks
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
