JBarca
Jun 13, 2023Nomad II
rvman69 wrote:
Ok a rebuilt cooling unit it is. Will the rebuilt units that come with new flue have the place for the thermal breaker? Or do you have to make the spot. Thanks
Usually, none of the sheet metal covers come with a new cooling unit. You reuse all the old sheet metal covers and in this case, the boiler tube insulation cover. You can double-check with the place you are buying them from.
This may help. The last cooling unit I bought was from RVCool. I believe they are no longer in business, they sold the business to someone else, not sure I recall who. This is what they shipped for an RM2652; it was a new cooling coil. It was a well-built unit, in my view. And you had to return your old core to them.
This may help; this was their install video. This can give you a feel for what is involved. After the 2 adds, the screen will be black for a few seconds until the words and people start showing up. https://youtu.be/L8kBX9LzIJo
Hope this helps
John
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
