dougrainer
Jun 14, 2023Nomad
NEW Dometic Cooling units have the complete CU with the Thermal disc. You only transfer the baffle. Since the Thermal disc is a Dometic part, I doubt any rebuilder will have or supply the disc. Usually over the years if you give Dometic a call and give them the model and serial number, they sometimes will ship a disc. No charge. But, I am a service center and have a relationship with Dometic, so they may defer to my knowledge and send N/C. There are 2 Dometic thermal discs. NO RESET when it trips you replace it. Manual reset with a button in the center you can push and reset. Note. Make sure you use LOTS of Thermal mastic when replacing the CU. You can NEVER use too much. Doug
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
