dougrainer
Jun 14, 2023Nomad
You pull the cooling unit and the evap fins pull out with it. I use an Impact screwdriver to remove stuck evap screws. Doug
Stainless steel and you can "pull" the evap fin assbly around the stripped screws. Just use a small washer when you install the fins on the new CU
https://www.amazon.com/CRAFTSMAN-Impact-Driver-8-Inch-CMMT14104/dp/B07R96M9VW/ref=asc_df_B07R96M9VW/?tag=hyprod-20&linkCode=df0&hvadid=366281307321&hvpos=&hvnetw=g&hvrand=2019199461366032935&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027230&hvtargid=pla-792201167904&psc=1&tag=&ref=&adgrpid=75985294253&hvpone=&hvptwo=&hvadid=366281307321&hvpos=&hvnetw=g&hvrand=2019199461366032935&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027230&hvtargid=pla-792201167904
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
