rvman69
Jun 14, 2023Explorer
I have watched a bunch of videos of replacing the cooling unit in the Dometic RM2652. Most of the people remove the screws in the freezer and the fridge fin screws before they take the fridge out. I did pull the plastic at the bottom of the fins out good since I will definitely be pulling the fins with the cooling unit. I did not have a bent screw driver so I bent an old hacksaw blade then used electrical tape to tape it to a long flathead screwdriver. It made it sturdy and it worked perfect. It will be easier to worry about those two stripped screws when the cooling unit is out on the ground. I am wondering if I can take the door handles off and maybe the hinges to be able to take the fridge out of the camper. The actual door opening is just under 24 inches. Anyone tried this? Thanks
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
