rvman69
Jun 17, 2023Explorer
Jim, thanks. But I think he is installing an Amish built new unit. The unit I got was a factory rebuild from the Amish. I am sure they replace that pipe as well as others. So maybe that pipe is longer. The element starts hitting at the curve before it gets low enough. So I will cut that part out if the new element is the same way. Any suggestions on a good heating element that wont break the bank? Anyone had any experience with the cheaper elements? If I need to spend more I will because I want it to be dependable. Kinda glad it broke. I should have went ahead and ordered one. But then I might have messed up the new one messing with it. I will go ahead and get everything else done and put it back in its spot. I can put the element in when I get it. Thanks
