CalGal2
Jan 27, 2017Explorer
The guy who did the fan swears he rechecked it outside when we were not here and said it was plugged in and/or has power. Now I know the light runs on 12v, that helps me in trouble-shooting thank you - means I need to personally check both the outlet (assuming it is not hardwired) and make sure plug is secure. Plus at that point I can try the plug/unplug (either the frig or the whole TT) to see if it just needs a reset of some sort. Will start with that over the weekend and update this. Thanks!
BTW - to answer the "Check" indicator light question... that comes on when the propane is out or shut off (and that is also when the frig stops cooling too).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
