Old-Biscuit
Jan 27, 2017Explorer III
Not only check that the AC power cord is plugged into the outlet (in outside compartment) MAKE sure that the outlet is HOT....could be dead due to tripped circuit breaker or GFCI outlet.
Panel lights, interior lights & control work off 12V DC
Note: IF fridge is in 'AUTO' if will swap to GAS when no AC is available and would swap back to AC when power is restored.
Can only manually select GAS
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
