Terryallan
May 19, 2013Explorer II
kmb1966 wrote:ScottG wrote:
As Terry said, the light only indicates auto and does not indicate AC or gas unless you force it to gas only. Then the auto light extinguishes and the gas light comes on.
When I unplug it, I hear it switch to gas, but no indicator light except AES AUTO
Gas indicator remains off.
Yep that's right. the Auto light stays on. Indicating, it is in Auto mode. Sounds like it is working properly.
If the Auto lite goes off. There is a problem, and the fridge is not working. The only way the gas lite should come on, is when YOU turn it on. By switcing from Auto to gas manually. IE push the gas button in. But then, It won't switch back to electric when you plug it back up
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
