MikeJinCO's avatar
MikeJinCO
Dometic Frig Temperature Adjustment
The refrigerator in our Host Mammoth is on of the cheap non adjustable models(that is a slam) a 2852. Ours is too cold. I read about the adjustable thermister on some models, but the only temperature switch I can find is fastened to the finned heat exchanger at the top. The control box cover also doesn't want to come off to accurately trace the thermister wires. Any Suggestions?
  • Adjusrable is a loose term. To make temp adjustments you slide the thermister up or down the fin. A little is a lot, so go slow and allow the refer to adjust before taking a reading. If you wa*nt a decent reading, place a thermometer in a glass of water.
