Marcela wrote:
Don't think so, but I'll let you know if anything changes.
Chris and I are both RV professional's. If we say to do something, there is a reason:B It will fail again and when it fails, odds are you will be NEEDING the furnace! I have seen this type problem since they went to the new style sail switches and the logic on the newer control boards. It used to make diagnosis difficult, because when you went in to check the various items that cause your type problem, moving things causes the sail switch to start working. Until it decides to stick and fail again. The fact that it did NOT work until you messed with it proves my point. Doug
