campsmoke
May 11, 2013Explorer
Thanks for the info Doug - everything else on 12 volt worked fine in the coach - now I am wondering if perhaps the voltage regulator in the alternator is going bad! As I had mentioned we could not get it to run on shore-power - gas - or 12 volt. But now it is running perfectly!I will get a 12 volt monitor and see if we can isolate the problem. Thank you all for your input! safe travel!
