campsmoke
May 15, 2013Explorer
Our fridge/freezer has gone off completely the last two nights as the outside temp dropped to the low 30s - when the outside temps rise i will start again and run on shore power or propane - I think that the problem is with the board that is located at the rear back of the fridge - it may be cracked or something. I went to the "clicky" site that one of you gave me and found someone who had the same problem as I and the online tech mentioned this as a possible solution.
