kmb1966
Nov 04, 2018Explorer
Dave H M wrote:
Mine is exactly like that. It is the left side as you are facing the fifth wheel. Been that way for years. i just unroll a little, then reach out the door and give the stuck arm a yank and it pops right out. The cause is some sort of binding in the fold up mechanism, I just have never fiddled with a fix if there is one. My money is that the spring/shock is not your problem.
Thanks for the feedback, when yours is completed extended, can you easily push on that one side and make it fold in? Mine has no tension on that one side. So my problem may be slightly different. It not only extends out needing help on that side, that same side has no tension when fully extended.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
