CdnTxn wrote:
2000 monaco diplomat
Replaced both AC units with dometic penguin heat pumps model 651816.
Replaced thermostat with new ccc2 10 button thermostat.
So 2 zones.
Zone 1 (front unit) works great on everything, ac heat pump furnace etc.
System will not pick up zone 2. Did reset. Nothing. Dip switches set properly to zone 2.
Replaced communication line between the ac units, did reset, nothing.
Tried going direct with thermostat and 12v power to back unit set dip switch for zone 2 to off so that unit was zone 1 now.. Independently it works as it should.
But with front ac as zone 1, zone 2 does not show up on thermostat.
When 2nd ac is connected with communication line E01 shows on thermostat and sometimes back unit starts. Not zone 2 though on display.
Help please...
Did your New AC come with the bolts to secure it? Mine didn't and I'm trying to figure out if it was supposed to or not. Thanks for the input.
