LouLawrence
Aug 25, 2022Explorer II
Yep, likely just stripped. You can slip something between the screw and the shroud to act as a wedge and turn screw slowly. The good threads behind the stripped ones should grab and allow you to unscrew. Google remove stripped screw and you will find lots of other ideas.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
