Jerry_B's avatar
Jerry_B
Dometic Refer light question
I have a two door Dometic MDR-1062 refrigerator that the inside light won't work. The light will work with the Low Ambient Switch so this tells me bulb and circuitry is ok. Must be the door switch. The door switch housing seems to be attached to the refrigerator with four plastic rivets that I am unable to remove. Anyone ever had one of these apart?.
  • Jerry B
    According to this parts list and diagram those are expansion pins (push pins)
    Pg. 7 & 8 part #35. Switch is part #41
    Link to parts list
  • Yep, the light is under the cover, but the switch is in a little compartment that is attached to the top of the fridge box. The attachments are four little plastic things that looks like rivets? Wonder, could these be plastic push pin things?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Are you able to remove the lamp cover? On mine the door switch is under that cover but you have a different model.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
