Old-Biscuit
Jun 17, 2015Explorer III
12 hrs. minimum for Refrigerator to cool......
Freezer section needs to get down to 10*F or colder before you will get sufficient cooling in food section.
Thermistor.....
That is the temp sensor in food section that the thermostat uses for temperature control.
Thermostat is factory preset to control for 38*F to 42*F in food section.
Very minor affect can be made by movement of thermistor location on far right fin (4*F to 6*F change)
Clip should be mid-position with tip (bulb) of thermistor just protruding above clip.
Move UP for cooler temps
Move DOWN for less cooler temps
Wait overnight after movement to check for change in temps
Thermistor.....
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
