afinepoint
May 21, 2017Explorer
I agree regarding the pin. I used epoxy but the door is a puzzle. I started loosening the hinges then realized they appear to be screwed from the sides as well. As you say the unit would have to be withdrawn to access those screws. I removed the hinge between both doors. The inside then shifted causing a hole misalignment. It took several minutes and clamps to realign the holes to get those machine screws back in. Why machine screws? What a design!
OK so how did you do-it-yourselfers make it happen? I've yet to read any how to rehang the door.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
