Old-Biscuit
Aug 31, 2014Explorer III
First check that outlet fridge plugs into has AC power
If the 5A fuse on control board is good......then need to check the electric heater element.
Best way to check it....unplug it from control board and then connect it to 110V AC power directly.
This will check that heater element works and whether problem is with element or control board. If it works wired directly...control board is bad.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
