j-d
Aug 31, 2014Explorer II
If the fridge is Three-Way (LPG + 120VAC + 12VDC) then it'll have a 12VDC element in addition to the 120VAC one. Three-Ways aren't all that common anymore. The 120VAC element tests across its two wire. The 12VDC element tests one wire to ground (its shell). If a 120VAC element has continuity to its shell, it's bad.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
