onthebus
Sep 02, 2014Explorer
The RM2652 is a dual fuel unit. If there is AC power it runs on that and when there is no AC it runs on propane. The DC voltage is for the controls and gas ignition. If the gas is shut off with no AC hooked to the vehicle both lights on the control panel come on indicating the unit is not running. I have a 120 AC heater (tested bad) on order and because the unit still runs on gas I believe the heater replacement will fix my problem. If not I will have to replace the board.
Thanks to all for your input
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
