dougrainer
Sep 02, 2014Nomad
onthebus wrote:
The RM2652 is a dual fuel unit. If there is AC power it runs on that and when there is no AC it runs on propane. The DC voltage is for the controls and gas ignition. If the gas is shut off with no AC hooked to the vehicle both lights on the control panel come on indicating the unit is not running. I have a 120 AC heater (tested bad) on order and because the unit still runs on gas I believe the heater replacement will fix my problem. If not I will have to replace the board.
Thanks to all for your input
1. There is NO indication on a Dometic refer, when any part of the 120 system fails(fuse or element) other than the refer will NOT cool
2. It takes 12 volt DC power to operate the refer on 120 also.
3. If the 120 element tested bad, all you have to do is test the 2 spade terminals on the control board for 120 current. THAT will tell you if the control module is bad. No current? Check the 120 fuse on the board. Doug
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
