onthebus's avatar
onthebus
Dometic Refrig. won't run on AC
I have a Dometic RM 2652 Americana which runs fine on gas but will not run or switch to AC when available. I have checked the two fuses on the circuit panel and the AC circuit breaker of course and all are okay. Any help will be appreciated.
  • Is the RV plugged to the A/C power, are the brakers in the RV's control panel not tripped, is the fridge pluged to the A/C socket next to the fridge, axcesed by taking the fridge panel off, normally on the left side, are all the fusesin the fridge control panel OK.
    Is the GFI out let in the bathroom or galley triped? some times the fridge cirquit is part of the outside contact and is protected with a GFI contact inside.
    Other than this I would be at a loss to.
    navegator
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
