otrfun
Oct 02, 2013Explorer II
I would double check to make sure there's no insulation or other obstructions (dust, trash, paper) near any of the rear coils. Not sure how these older units are designed, but the "baffle" (the wall that faces the entire rear of the frig) on the newer units should be no farther than 1/2" - 1" from the rear coils. This small space creates a "venturi" effect and actually increases cooling when temps rise.
What kind of fan, CFM, and where is it installed?
I wouldn't ignore that small gap in the door seal. If the door seal won't hold a piece of paper then I'd seal it with something.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
