enblethen
Aug 10, 2015Nomad
1) Verify 120 volts is present in receptacle.
Locate the two small wires going to the stack from the circuit board.
2) Use a volt meter to check to see if there is 120 volts coming out of the circuit board.
No, voltage, bad circuit board.
Voltage, disconnect power to the refer, disconnect the wires going to the stack. Use Ohm meter to check for continuity. No, continuity, bad element.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
