bobrizer2's avatar
bobrizer2
Dometic RM 1350 refrigerator door seals
I needed to replace the door seals on my Dometic Rm 1350 refrigerator. I found a part number from a Dometic parts manual. I tried to order them from PPL and was told that you couldn't replace them, you had to buy new doors. Being that it was a 4 door refrigerator, it was going to cost as much a a new domestic refrigerator. That just didn't seem right to me. So I kept looking. I was able to order gaskets from Dyers RV and got them in just 2 days.
So now I had the gaskets but didn't have a clue on how to change them. I found instruction s in a Dometic instruction pamphlet. It said to remove refrigerator doors, cut the gaskets loose wthh a box cutter, remove any stuck on glue, install the new gaskets using double faced tape, let the glue cure for days, etc. Sounded like a big project to me. Well it turns out the door gaskets are only pressed into a groove on the doors. Pull the old gaskets off and press on the new ones. No need to remove any doors or wait for days for glue to cure. The repair is a piece of cake.
To make your gaskets last longer, spear a thin coat of Vaseline on them. It keeps them from sticking and tearing the gaskets
  • Please supply the part number for the RM1350 door gasket kit. I can't find it. Thanks!
  • C_B_'s avatar
    C_B_
    Explorer II
    You don't say why your replacing the door seals.
    Here's hoping you don't have the same problem I did.
    The problem was the seals weren't sealing tight and condensation would collect on top of refrigerator compartment doors.
    After 2 years and 2 new sets of door seals. Dometic determined my doors were warped and replaced them under warranty.
    C.B.
    And makes things messy with Vaseline
    Just wipe clean with damp cloth....then rub them down an old sock with talc powder in it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
