LandDnAZ's avatar
LandDnAZ
Dometic RM 2652 won't turn off
The Dometic refrigerator in our 2004 Nomad travel trailer won't turn off. Model # is either a RM2652 or a RM2852 (not sure which). The refrigerator works great with gas and/or electric - just won't turn off. If gas is off and the trailer is plugged in, it keeps running even if switch is off. Only way to turn it off is to unplug trailer and turn off gas. We have replaced the thermistor and just recently replaced the refrigerator panel control board. Not sure what to check next. Any suggestions?
  • When you push the ON/OFF button does it go in (ON) and out (OFF)?
    Button in out position and LED ON light still lit......upper control panel issue
    Display panel #2932771021
  • Sounds like a bad panel switch. Either that or the control board has a short onnit.
