You_can_t_take_
Oct 15, 2019Explorer
I would try replacing the heating element. I had an issue once that was popping the 120V GFCI every time the fridge element kicked on. The fridge element obviously had some sort of internal (short?) problem. It would work fine and tested great.. but the GFCI problem disappeared after I replaced the element. They can be tricky at times...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
