Gjac
Oct 19, 2019Explorer III
enblethen wrote:I would second what Bud said, the dinosaur techs have helped me several times, the last incident was a intermittent connection which was an easily fix but I would never have found it by myself. I would probe the connectors from the board to the 120v heater. Do you see 120 volts at the connections? If so check your GFI, is it tripped? If so change the element.
A recurring problem would not be a circuit board. It could be an element or connection on the output of the circuit board to the element.
I would call Dinosaur as they have some good people that could help with diagnosis.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
