Ivylog
Jul 06, 2012Explorer III
Put any fan you have in the outside vent and see if this helps. The temp of the freezer at the bottom of the back wall has to be below 15 degrees inorder for the refer to get cold enough. If mounted in a slide then you need to rework the baffles to improve the air flow plus fans.
