Ivylog
Jul 08, 2012Explorer III
Ron, I see where you installed a generator... implies you boondock. Putting a a home refer is not a just swap it out. You'll need more batteries and possibly a seperate inverter. Getting the units in and out may be a problem as they may not fit through the door.
If you buy ice cream in rectangle cartons and put it on the bottom against the back wall it will be solid as that is the coldest part of the refer.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
