Howie63
Jul 23, 2012Explorer
JC2 wrote:chevyman486 wrote:
Again thanks for the advice. I think I will try a third fan to see if it will cure my problem. Also I'll put the ice cream in the bottom back part of the freezer or i could continue eating it all gone the same day I buy it. LOL
The type of fans that I have used are the 3-4 inch computer case fans(8-$15) available @ Radio Shack or any computer store. Don't need anything fancy, just a plain Jane fan and perferably controlled with a toggle switch.(Iwould also consider putting any existing fans on a toggle switch if they are easily accessible) Here are some pics to go buy. http://www.amazon.com/s/ref=nb_sb_ss_i_0_17?url=search-alias%3Daps&field-keywords=computer+case+fan&sprefix=computer+case+fan%2Caps%2C223
I went with modified baffles and a pair of 110V 120MM fans mounted to the top side vent panel blowing out. Plugged them directly to a three way adaptor add where the frig plugs in. The only time I run on gas is when traveling. There seems to be no venting issue at 70 MPH running down the interstate. They come on and run full time when on electric. Always need them running in Florida and can simply open panel and unplg for those two days of cool weather here in the winter.
Got the mounting idea here:
http://www.heartlandowners.org/showthread.php/22581-Dometic-RM1350-Operation
Post #17
