dougrainer
Nov 11, 2017Nomad
DC(3 way refers), are NOT supposed to use DC element for cooling down a refer. The 12 volt element is a sustainer of the existing cold temp and is used while in transit. Doug
The 12 volt element is NOT using the tstat control. There was no reason to remove the 12 volt element when they replaced the 120 element. The tubes are welded to the flue. When you switch to DC, the 12 volt current is applied direct to the element and not thru the tstat control system.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
