dougrainer
Sep 16, 2019Nomad
kjmaggart wrote:
I took a gun cleaning brush and cleaned out the tube. I went all the way past the holes. There was no debris. My next task is to check the pressure. Both stove units burn bright blue with plenty of flame. So, I believe the problem would have to be after the split to the stove.
Also,as a footnote, the water heater works very well. Only 20-30 minutes after turning on that we have nice, hot water.
You need to pull the refer and remove the spiral baffle and then clean the flue tube. 11.5 inches WC is the LP pressure. Your stove operates at 10 inches WC. It has its own regulator that drops the LP pressure. The water heater also will operate with lower than spec LP pressure. Just a drop from 11.5 to 10 inches will affect the LP flame on the refer. Doug
