BFL13
Jun 10, 2020Explorer II
Unplug the 120v input cord from the circuit board and check that cord. It may be shorted somewhere. Check where the green wire from it is screwed to the chassis by the plug to the board.
Un-do the 120v element from the board and check that. You can run the element directly using a made-up adapter by-passing the board to see if it heats up ok. All the board does is provide a thermostat to control the heat element to be on and off.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
