enblethen
Jun 10, 2020Nomad
Did you use an Ohm meter to check element to ground?
Relay on circuit board could be problem. You could pull circuit board. If relay is the issue there will be burnt area on back of board.
Resistance is not that far off. That much variation could be in different meters.
If you change out circuit board, I recommend a Dinosaur Electronics version.
Problem is between the 120 volt fuse and the element not in cord.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
