dougrainer
Sep 20, 2022Nomad
1. ALL white wires EXCEPT the 2 pin connector below the 6 pin connector are GROUND wires. The 2 Pin with white is the Temp Thermister that goes to the refer evaporator. So, if you have a white wire that is NOT connected, that means the control board is NOT getting the negative signal to operate. Has nothing to do with the Climate control system. Pic would help a lot. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
