SoundGuy
Oct 22, 2018Explorer
No need to cut wires at the switch in the eyebrow ... at the interior light there should be 2 red wires, one heavier gauge than the other - cut that and power to the climate control heating element will be killed. Later model Dometic DM2652 fridges have this heating element as well and although the schematic for this fridge indicates there is a switch there isn't so the solution is to cut this heavy red wire and either leave it disconnected or install one's own switch at the light so the climate control can be still be used when desired.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
