SoundGuy
Oct 23, 2018Explorer
bob213 wrote:
SoundGuy..do you have both wires going thru your switch? Is the thinner wire for the light?
Thinner red wire powers the light, leave it alone. Cut the thicker red wire and power to the climate control heating element will be cut. After cutting this wire I wired it through a simple SPST toggle switch so I could still use this heating element when running on shore power and conserving battery power wasn't an issue.
To the OP - in the time it's taken to describe you could have cut this wire and been done with it. Your choice. :R
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
