rvman69
Jun 21, 2023Explorer
I got it figured out. When I first realized the cooling unit was bad for sure I messed with the two far left red wires before I took a picture. I know better than to do that. I dont even remember why I took them off now. Well when I put them back on before I took the fridge out I put the 12v coming from the 12v block to J3 instead of J1. So that is why I had light inside the fridge. J3 and J2 are hooked together and are feed 12v from the board. So the way I had it hooked up the only thing on the board that had 12v was the interior light. Now to the next issue. I dont have a heating element in it yet. (It is suppose to be here tomorrow) I have the fridge plugged in and I go in and turn it on. Then I come out and unplug the fridge from 120v to test the gas part. It does its thing and then the gas valve opens and I can hear the gas coming out but the ignitor did not fire. Any ideas what could be going on there? Is there a delay before the ignitor fires off after the gas valve opens? It worked before but we dont use propane very often. Basically just when we travel from home to campground. Thanks
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
