bigfootford
Jun 27, 2023Nomad III
rvman69 wrote:
Ok I got my new Electrode in today. I installed it and I do get a spark but the flame will not light. I lit it with a long grill lighter and the flame looked good and blue and stayed lit until I turned it off in about 30 minutes. I dont think the gap and position of the tip of the electrode is good. How can I adjust the gap and position of the electrode? Can you bend it? Thanks
Should be able to bend the little tab that is held by the little screw. If not just bend the electrode. Make absolutely sure your hands are clean and NO oils when touching the ceramic isolator.
Test the electrode with a screwdriver. Hav e someone turn the fridge on while you use the screwdriver to almost shot the tip of the electrode.
Should hear and see the spark. Valve opens with a click and a millisecond later the spark should occur.
Your back from your trip?
Jim.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
