rvman69
Jun 28, 2023Explorer
There is only one place on this board that the gas valve and ignitor power can plug into. The 12v power wire goes from the control board to the gas selenoid valve to the ignitor. I guess I should check and make sure it is not loosing voltage from the selenoid valve to the reignitor. My board is 385 04 15-01 if I replace it with a Dinosaur board does it have the reignitor built into it? I was told you cant get a replacement reignitor. Do I use the original thermocouple and ignitor? I dont want to buy a new board if the reignitor is bad and cant be replaced. Thanks
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
