rvman69
Jun 29, 2023Explorer
The board on mine is wired different than what Dave shows on that link. (See pics) I only unplugged wires I had to unplug to get it apart. I left the main board, reignitor and gas valve assembly all as one piece when I took it off. So I did not undo any of the reignitor connections at all. I undone the ground where the reignitor grounds to but just to take off the ground wire that goes to wires that go to top of fridge. I cleaned them up when putting the one back on. I will check for 12v at the gas valve and then at the reignitor. Like you said if I have 12v at both places the main board is doing its job and it has to be the reignitor or a problem at the electrode. If you notice in my pic I had the 12v from the block to the wrong place when I first put it back in. That is why the fridge light worked at first and nothing else. The red wire on right side belongs on the Batt terminal on the far left. I have not been able to do anything today so far. We have had some bad storms. Thanks
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
