bigfootford
Jun 29, 2023Nomad III
Well I do see the igniter/solenoid output connector on the control board wiring is different from you board.
Dinosaur says:
*Warning: The Micro P-711 CANNOT replace any Black Box Board part number that starts with "385"! You must identify
the part number of the physical board that is actually in your refrigerator now! Failure to do so can result in getting the wrong
board! Please look on the black cover or under the black cover for a part number that begins with "385 or "293"
I noticed that your board says Canada on it...Wonder if that is the reason it is different. I have no clue about that.
If you have the 12vdc coming off that Yellow wire when it is ignite time then the control board is good. Igniter would be in trouble.
If you are in doubt I would call Dinosaur or email them. They are good folks.
Bryant's and dougrainer are fellas that have been in the RV service business for years and have been valuable for tech support on the appliances etc....On RV.net.
Here is a nice write up from Bryant's about the fridge theory of operation...
http://bryantrv.com/refcontrols.html
Jim.
Dinosaur says:
Jim.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
