rvman69
Sep 05, 2023Explorer
I finally got the new reignitor installed this past weekend. I had to install it at a little of an angle. I did not have as much room as in the video. I think this was because of the new pipes that were reworked on my Amish rebuilt cooling unit. It works great. Once I got it installed I turned the gas valve at fridge back on. Then I unplugged the fridge and it fired right up on the first spark. Then I plugged the fridge back in. I waited about 10 minutes and tested it again. It fired right up on first spark. I only had to change the end on the electrode wire. The factory negative and 12v plugged right into pins on new unit. Mine did not come with the big black boot like the one in the video. Mine just had a small little boot. So I used the boot off of the number 5 coil I replaced on my motorhome and it worked great. So my original reignitor was bad.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
