marcsbigfoot20b27 wrote:
You may need to trade in that salvaged fridge from the Titanic and get a new cooling unit if the rust is that bad.
Hahahaha, Well it is 17 years old and who knows how old the stock was when installed in the trailer. The only rust is right there at the burner. Not sure about up inside the flue. The anti-corrosion coating gets oxidized away by the flame evidently because the only rust is where the heat was concentrated. Everything else on the back of the fridge looks good and clean. I just wonder if that flue apparatus is available as a replacement part.
