bentSpaceTime
Aug 30, 2018Explorer
dougrainer wrote:
Take a 5/16 open end wrench and tighten the nut from the Thermocoupler at the safety valve. Odds are it is slightly loose and that will stop the millivolt signal to the valve. Doug
Wow! Took 2 seconds and it appears to have fixed the problem! Thank you!
Is there any reason to cut off the rust on screw and do the recommend cleaning preceedure from the manual?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
