dougrainer
Aug 30, 2018Nomad
bentSpaceTime wrote:dougrainer wrote:
Take a 5/16 open end wrench and tighten the nut from the Thermocoupler at the safety valve. Odds are it is slightly loose and that will stop the millivolt signal to the valve. Doug
Wow! Took 2 seconds and it appears to have fixed the problem! Thank you!
Is there any reason to cut off the rust on screw and do the recommend cleaning preceedure from the manual?
YES. You will be surprised at how dirty the burner area will be with rust and flaking paint and such. IF you have access to a compressor, blow out the flue above the burner, to remove build up on the Spiral baffle INSIDE the flue tube. I rarely remove the burner, I clean out with a small brush and compressed air from the shop compressor. Then vacumm up the debris. Doug
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
