j-d
Jun 09, 2014Explorer II
We had a Class C with a 763, and you described the way it worked. The LED shouldn't go to red, but still, are you sure the thermostat is calling for cold?
The control board is a little hard to get at, but there's a fuse on or near it. I remember extending wire out to get the fuse external.
Also remember the board's edge connector got wet on that model and Dometic recommended reversing the mounting position.
You can pull a manual down here.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
